Hi all,
I want to ask you which 140mm fans to use for the best cooling effect with low noise.
I would have:
Also which one would you choose for 120mm? Noctua A14 PWM chromax, T30 MAX, etc.
As a last question, what would configuration be like? Both front and side front as intake and back and up as exhaust? Or there is any other better solution?
That's good to decide before I start building everything together so I don't do this twice.
Thank you in advance.
I would have:
- 3x 140mm in front (or 4x120mm)
- side 4x120mm (can't have 140mm)
- at the top, I will have Arctic LF 420mm AIO, so 3x140mm
- back 1x140mm.
