E _Epix_ Reputable May 7, 2014 371 0 4,860 Jun 1, 2014 #1 I want to put the H80i on the rear of the case. Will the cooler fit? Thanks in advance
Solution terry4536 Jun 1, 2014 The are designed to replace the rear exhaust fan. So, I don't think you would have any problem fitting it in the case.
terry4536 Glorious Mar 28, 2010 9,743 6 46,265 Jun 1, 2014 Solution #2 The are designed to replace the rear exhaust fan. So, I don't think you would have any problem fitting it in the case. Upvote 0 Downvote Solution
E _Epix_ Reputable May 7, 2014 371 0 4,860 Jun 1, 2014 #3 terry4536 : The are designed to replace the rear exhaust fan. So, I don't think you would have any problem fitting it the case. thanks for the help really appreciate it Upvote 0 Downvote
