Corsair 750D Cooling Questions
ExoticGecko
21
1. What is the best cooling configuration in the 750D with a 240mm radiator like the H100i? Two 140mm intake in the front, H100i exhaust and rear 140mm exhaust? Or something else?
2. Does the case provide enough airflow for SLI? I've been reading some reviews that say that this case doesn't provide enough airflow to the video cards. Is this true?
3. If you were to suggest another case with similar properties to the 750D, what would it be?
1. I have this case, and i will be using 2 Noctua NF-A14's for the front, and move the stock fans to the rear as exhaust. im using the Swiftech H220 for my cpu Cooler.
2.i hope not, as i am thinking about SLI for the future. i wouldnt have thought so, because its a fair size case, especially if you generate good airflow.
3. alternative cases, with around the same value: NZXT Switch 810 Hybrid Black.
ThermalTake Urban S71 Black
Links: http://www.scan.co.uk/products/nzxt-switch-810-hybrid-black-full-tower-silent-performance-case-with-usb-30-and-side-window-w-o-psu
http://www.scan.co.uk/products/thermaltake-urban-s71-black-full-tower-case-with-window-kit-w-o-psu
http://www.ncixus.com/products/?sku=79583&vpn=H220&manufacture=Swiftech&promoid=1114
http://www.scan.co.uk/products/140mm-noctua-nf-a14-pwm-1200-1500rpm-premium-quality-fan-with-noctuas-aao
The case already has a few fans installed but the Noctuas will really help. I have this exact case and cooler so I have it in a pull and push config. The H100i is installed on the top and my two GPUs on the bottom. There are two 140mm fans in the front pulling air and there is one 140mm fan in the back. I also have a pull config on the bottom where there are w 120mm fans. These are all the configs you can do from Corsair's website: Front: (x2) 120/140mm, Top: (x3) 120mm or (x3) 140mm, Rear: 120/140mm, Bottom: (x2) 120mm
