Question CORSAIR 850 CPU power connection clarification please.
Feb 4, 2023
Hello; Can someone clarify something for me please, Just bought a Corsair 850X power supply and I noticed that my motherboard msi mag z790 tomahawk wifi ddr4, requires 2 8 pin CPU power cables, would I use the two slots below the motherboard connections?
I'm just confused because the bottom 4 connection are identical and its labeled PCIe/CPU, can I plug both 8 pin CP and on PCIe on the bottom 4 slot? Then there's a separate single connection on the back which is also labeled PPCIe/CPU.
https://multimedia.bbycastatic.ca/multimedia/products/500x500/153/15397/15397408_4.jpg
Any assistance is greatly appreciated.
Thank you
Thanks for the quick reply,
So all 5 PCIe/CPU pinouts are interchangeable thus it doesn't matter which of the 5 I select as my PCIe connection nor which 2 I select for my CPU?
Again thank you
