xayxa30 Distinguished Dec 24, 2015 36 0 18,530 Aug 29, 2016 #1 How does one know how to make the fan intake or exhaust? I thought there would be an arrow showing airflow direction but I do not see it. Is there some other trick that people use to determine air flow direction?
Solution S S Samer1970 Aug 29, 2016 Usually the front is clear of any beams cross, and Air Goes from front to back . you can also tell by looking at the blades, if they are pointing left thats the front.
Isokolon Judicious Jul 24, 2016 6,369 108 34,390 Aug 29, 2016 #2 usually: there is the frame/cross bars holding it together on the back side. it takes air in from the front, exhausts at the back Upvote 0 Downvote
Mr Kagouris Judicious Sep 7, 2015 3,966 2 32,565 Aug 29, 2016 #3 The side with the beams holding the fan hub is the one that air comes out of. Upvote 0 Downvote
S Samer1970 Admirable BANNED Oct 23, 2014 1,729 1 6,460 Aug 29, 2016 Solution #4 Usually the front is clear of any beams cross, and Air Goes from front to back . you can also tell by looking at the blades, if they are pointing left thats the front. Upvote 0 Downvote Solution
xayxa30 Distinguished Dec 24, 2015 36 0 18,530 Aug 30, 2016 #5 Okay that makes sense.. I think I was making it harder than it was. Upvote 0 Downvote
