So yeah, I was planning to replace the loud fans that came with the Phanteks Enthoo Luxe and need some help in choosing between the Corsair Quiet edition or the Be Quiet Fans. Anyway, these will be connected to a fan controller (linked below) and I want this build to be as silent as possible. I already have led, RBG lighting but more doesn't hurt and I plan on getting 1 static pressure fan for my radiator (single rad) and 3 airflow fans for top intake. Basically having them pull air into the case. Which one would you guys suggest and why? Thanks 😀
Links:
Fan Controller: http://www.scan.co.uk/products/nzxt-sentry-3-54-touch-screen-fan-controller-matt-black
BeQuiet Fans:http://www.scan.co.uk/products/140mm-be-quiet!-shadow-wings-quiet-fan-pwm-max-speed-1000rpm-noise-100-184-db(a)
Corsair Fans (AF): http://www.scan.co.uk/products/140mm-corsair-quiet-led-fan-af140-led-red-single-pack
Corsair Fans (SP): http://www.scan.co.uk/products/140mm-corsair-air-series-sp140-red-led-high-static-pressure-fan-single-pack
Links:
