Hi all,
First of all I'm sorry if I am posting this thread in the wrong category and if I'm breaking any rules, I will remove it immediately.
I currently own a Corsair H80i v2 and I have a question to ask.
So I attached the pump connector to the CPU fan header and set it in bios with DC and 100%.
When I open Corsair Link, I have 2 modes for the pump, quiet and performance.
When I set my pump to quiet, Corsair Link says approx. 1890 rpm, HW Monitor says approx. 930 rpm.
If I set it to performance, in Corsair Link rpm goes to 2850 and on HW Monitor says 1413/1425.
Now, I always read that its important for pumps to be given 12v continuously simply because you put wear on the pump bearings designed to run @ 12v.
My question is, If I set it DC and 100% speed in bios is it a way of ensuring you are supplying 12v to the pump?
And does both quiet and performance modes work with 12v or quiet mode actually works with less since it decreases the rpm?
_____________________________________________
Specs:
CPU - Intel Core i7 6700K
CPU Cooler - Corsair H80i v2
Motherboard - Asus Z170M- PLUS
RAM - Corsair Vengeance RGB (32 gb @ 3200mhz)
Graphic Card - Asus ROG STRIX GTX1080
OS - Windows 10 Pro
Thank you
Specs:
OS - Windows 10 Pro
Thank you
