Corsair AIO With Noctua Fans
mircea.anton99
Commendable
Jan 30, 2018
16
I am going for a phantom 240 case from nzxt, since i REALLY like how it looks. After some research, i found that a Noctua NHD15 just wont fit and im thinking i should get the Corsair H110i AIO and maybe pair it with some noctua fans. Will this work similarly to the NHD15? Im guessing it wont have any problems cooling an i7 8700k and i could eventually overclock it as well.
Noctua NHD15:
https://www.amazon.com/Noctua-NH-D15-heatpipe-NF-A15-140mm/dp/B00L7UZMAK/ref=sr_1_3?ie=UTF8&qid=1519988890&sr=8-3&keywords=noctua+nhd15
Noctua Fans:
https://www.amazon.com/Premium-Quality-Cooling-NF-A14-FLX/dp/B00AEGRGNO/ref=sr_1_6?s=electronics&ie=UTF8&qid=1519988949&sr=1-6&keywords=noctua+nfa14
Corsair AIO:
https://www.amazon.com/Corsair-CW-9060026-WW-Extreme-Performance-Cooling/dp/B019955W7C/ref=sr_1_1?s=electronics&ie=UTF8&qid=1519988983&sr=1-1&keywords=Corsair+Hydro+Series+H110i
Also, i want to custom paint the noctua fans since they are very ugly. i will paint the blades white and the body black. will this affect performance?
You might gain a bit of performance, Noctua makes the best fans. However they are designed for optimized airflow and painting them could mess that up. At worse it will be the same as the corsair with a whining sound (from the paint)
