Corsair AX1200i and power to GPU
GameOfMoans
37
Hi Folks,
I've just about complete my first self build, and taking delivery of a GTX 780Ti tomorrow, so just wondered about power, I have in the cables bag several PCIe cables for the potential of multi GPUs.
I see some just have a 6 pin connector at each end, so you'd need 2 for one GPU as GPU takes 2 x 6 pin or some take a slightly different confirguration. Some also have one 6 pin for the PSU end and at the other a 6 pin and a spliced addtional 6 pin feeding off same cable for the GPU end.
Does it matter which one you use...single cable with 6 + 2x6 or 2 cables of 6 pin and 6 pin.
Will the GPU take as much power as it needs irrespective of cable configuration ?
Cheers in advance.
Similar threads
Latest posts
