Corsair Build or NZXT Build?
kaiozaslan
18
I'm about to build my first PC for my gaming rig, however, I'm torn on the parts. I have two builds in mind, one is an NZXT build and the other is a Corsair build. The parts for the NZXT build are - Case: H500i, CPU: i7 8700k, Motherboard: Z370-F, RAM: 16 GB Trident Z RGB 3200 MHz, GPU: EVGA GeForce GTX 1080 Ti FTW3, PSU: 750 watt EVGA Supernova 80+ Gold Rated, Hard Drive: 2 terabyte Seagate Barracuda, SSD: 250 GB Samsung 970 Evo, Cooler: Kraken x62, Accessories: Cable Mod Custom Sleeved Cables, replace all the fans with NZXT Aer RGB Fans. For the Corsair build the only things i am changing are the case (Crystal 570x) RAM (16gb3200mhz Corsair Vengeance RGB) Cooler (H150i) power supply (Corsair RMx 750 w 80+ gold certified) and all the fans will be the rgb LL fans. I'd appreciate any feedback on which build to do and any improvements. Thanks!
nzxt build
pros : you'll save few bucks on cabinet / recently launched / vertical gpu support / nice cable management
cons : seprate hue extension needed / only 1 fan mount on top side /
corsair build :
pros : tempered glass all side / icue software better than nzxt cam / i have used rmx series psu and it is best / more rgb and more tempered glass
cons : little costly than nzxt / front rgb lights can be disturbance while gaming or watching movies /
imo corsair would be good choice for building with same branding components.
nzxt build
corsair build :
