Corsair Carbide 300R best fan setup?
Criticalacc
58
Just wondering what the best airflow configuration would be for the carbide 300r im buyng soon. This is the fan setup I will have:
2 front 120mm led fans
2 side panel 140mm fans
2 top 140mm fans
1 Corsair H60 water cooler in the back
And a PSU fan on the bottom
Ive seen posts in blogs that say that all my fans should be intake fans and the top should be exhaust fans. Is that the right way to go? Is that too many fans in the first place? (I'll only have one GTX 760, but Ill be installing another one in the future) IMPORTANT Q: Will all of those fans make my rig too loud?
This my friend...Dont forget to Filter those side intake fans with a pair of these...
Silverstone 140mm Magnetic Fan Grill Filter FF141B
The standard configuration is to have the flow of the air directed to you main components (motherboard, cpu, gpu, etc.). The most common method is to have your air intakes from the front, bottom, and sides. You exhaust at the top and rear. As for the noise, it all depends on the fans and what rpm they will be operating at.
If you want a silent rig go for the 120mm Noctua NF-F12 PWM.
