[SOLVED] Corsair carbide 500R Front Replacement I/O
Rafalex
13
I know this case is ancient and all, but the front audio ports and USB cables have stopped working for me. While, this happened a ong time ago. It would be nice to get it working. So I just wanted to ask if anyone knows anywhere where I can get the front panel I/O, searched around amazon, ebay and gumtree already.
If you really only need the USB ports, the molded 2-port USB cable can be unscrewed from the front io panel. I've looked at photos of the 400R and 550D front io panels, and it appears that they use the same molded 2-port USB cable. So if you can find one of those instead, that may work.
