Corsair Carbide Air 540 build help
FeedTheBeast
15
Hey fellow Toms hardware enthusiasts,
I have recently built my corsair air 540 however i am stuck on what fans to get. I have bought all my parts and will latter get a corsair h100i for my CPU.
I am planning to get 6x 120mm fans and 1x 140mm fan. I have seen kier (http://forum.corsair.com/v3/showthread.php?t=121577) put triple 120 fans on the top and front so i believe it can be done.
I know that I will end up having corsair sp120 fans on the h100i (hopefully i will have 4). But for the other fans i haven't a clue. Considering I will not be getting a rad for the front or back i think maybe Af120 at front and AF 140 at back no?
Anyways i would appreciate if you could leave some helpful information, or even a link of a build that i could use as a simple design.
The H100i actually comes with SP120 fans, just they are OEM so they don't have the coloured rings or rubber mounts, otherwise they are the same fan.
I would probably just deck the entire case with SP120's if you have the cash to do it, its not like with that many fans airflow is going to be a problem. Though TBH, the stock fans (OEM AF120's and 140's) with the H100i fans would be plenty.
