S saman123257 Reputable Sep 7, 2017 4 0 4,510 Sep 26, 2017 #1 So I have brought my new case Spec 01 and Asus Strix Z270E mobo. I wanted to ask what should I do with the front panel usb 3.0 to connect it to mobo which has 3.1 connectors?
Solution C C Calvin7 Sep 26, 2017 The front panel usb 3.0 case cable connects to the Internal I/O Port 1 x USB 3.1 Gen 1 connector supporting additional 2 USB 3.1 Gen 1 ports The motherboard also has a USB 3.1 Gen 2 front panel connector that you don't have anything to connect there.
C Calvin7 Titan Feb 19, 2013 11,722 336 76,490 Sep 26, 2017 Solution #2 The front panel usb 3.0 case cable connects to the Internal I/O Port 1 x USB 3.1 Gen 1 connector supporting additional 2 USB 3.1 Gen 1 ports The motherboard also has a USB 3.1 Gen 2 front panel connector that you don't have anything to connect there. Upvote 0 Downvote Solution
