S sindre900 Commendable Jan 27, 2017 2 0 1,510 Jan 27, 2017 #1 Does anyone have a link for the front fan with same light effect like the fan which is already in there. the blue corsair spec-03.
Slow Pri Respectable Feb 29, 2016 586 0 2,360 Jan 27, 2017 #2 I believe there the Corsair AF120's. https://www.newegg.com/Product/Product.aspx?Item=N82E16835181056&cm_re=corsair_120mm_fans-_-35-181-056-_-Product If not there going to be hard find the exact ones since some cases come with generic fans and just LED's on it. I think this product would be the closest if not the same LED color as the front fan. Upvote 0 Downvote
