Corsair carbide spec-03 white led case fans
Sev3nt1
9
Hi eveyone! its about case fans, I have a Corsair carbide spec-03 white led, is it right this build:
2x140 mm at front (Corsair af 140mm)
1 x120mm at rear (Corsair af 120mm)
bottom and top cant fit nothing. thank you very much.
Per the product's specs page:
Fan Mount Locations Front: (x2) 120/140mm
Top: (x2) 120mm
Rear: (x1) 120mm
Bottom: (x1) 120mm
So you're fine with the fans you've chosen. You can fit two more fans at the top but the ram and motherboard VRM heatsinks might interfere but there are mounting locations for fans at the top for two 120mm fans.
