[SOLVED] Corsair Carbide SPEC-DELTA RGB splitter problem
marc873a
Commendable
Mar 1, 2021
7
Hi.
I have recently bought the Corsair Carbide SPEC-DELTA RGB case. My problem is I don't know where to plug in the RGB splitter cable. I bought 2 fan cable splitters so I could plug 3 fans into one connecter. I still have one fan splitter that isn't being used.
This is an overview of my current motherboard: https://mans.io/files/viewer/1220068/11#navigate_bar
If somebody could tell me where I should plug the RGB cable into, would it be really nice
Thanks in advance:)
There is a chance that could work but I believe the lighting node core is only meant for Corsair's resale fans. (ML, LL, QL, SP, etc). The SPEC-DELTA fans are proprietary to the SPEC-DELTA case.
I cant clarify if this will work though. For a SPEC-DELTA build I did, I had to plug that 3way splitter into a 4pin RGB header on my motherboard.
I bought a Cooler master RGB LED controller some days ago and it works fine now. I think I forgot to say it in here.
Thanks for all the help, I really appreciate it. :)
Hi.
Thanks in advance:)
Your motherboard has nowhere to connect the RGB lighting for the fans.
I think maybe getting this will fix it: https://www.newegg.com/corsair-co-8950020/p/1W8-005R-000C7?Description=corsair node&cm_re=corsair_node--1W8-005R-000C7--Product
my friend had a similar problem and then used this and here is a tutorial to set it up:
View: https://www.youtube.com/watch?v=EbKDfFrAXl0
