[SOLVED] Corsair Commander Pro Question.
lukemurtagh1995
Commendable
Oct 7, 2017
129
Hello all,
I have a question about the Commander Pro. I am looking to have one HD120mm fan on the outside of my Dark Rock Pro 4 for just a touch of RGB. I want to be able to control the RGB with Corsair software. What would I need to achieve this? I saw a YouTube reviewer who stated you only need the Commander Pro which would act as a fan hub for my other Noctua case fans but also provide power and RGB control for my HD fan. In a contradictory fashion I have seen posts on here and elsewhere which state I need both the Commander Pro and the RGB hub Corsair also sells. Could I get clarification on this please?
Thanks.
the commander pro has lots of fan headers
but only 2 rgb headers.
pretty sure thats what youre referring to
tho IF YOU REALLY WANT
the 2 become interchangeable
the rgb hub has 6 rgb headers
Thanks for the reply. So all I need to do is plug my HD120 power cable into one of the fan headers, the HD120 RGB cable into one of the RGB headers, and I should be able to control the RGB via software?
