[SOLVED] Corsair control nzxt fans + node control fan speeds?
Nov 29, 2020
36
I order 3 pack of corsair fans, comes with the lightning node, the less expensive node, this will allow me control the fan speeds right? Or will I need to connect the fans to the motherboard to control fan speeds?
I have a https://www.msi.com/Motherboard/MPG-B550-GAMING-CARBON-WIFI
I also bought a kraken nzxt aio, can I connect those fans to my corsair node to control all the rgb at once? I bought a Lian Li II RGB Mesh case.
Or could I use the motherboards software and connect all rgb to the mystic light and control all rgb, and if so how?
Got a link to the fans you purchased? The fans on the NZXT cooler and the Corsair unit aren't one and the same, the Corsair unit uses a proprietary connector, so , you can't control the RGB through the Node.
Latest posts
