I've got a few cooling and case config issues I'm hoping for some help / advice with...
System and case spec
I've got a Fractal Design Define R6 USB C case in an open internal configuration with the hard drives (2 SSDs and 2 3.5" HDDs) attached to the back of the back plate. The motherboard comes with a PWM fan hub, but I've not used that.
rest of the system is an Aorus Z390 motherboard, I7 9700K (stock) cooled with a Corsair H115i with the radiator mounted on the front, 64Gb Corsair RGB RAM, Aorus 3070Ti, and 2 x 1Tb M2 drives, one in each of the M2 slots.
One of the Corsair radiator fans failed, so I've just bought 3 x LL140s with the lighting loop and fan hub, and that's prompted me to ask questions about my system cooling!
Hot M2 drives?
Firstly, I don't know what temp things are supposed to run at... I think the core components - CPU, GPU - are running pretty cool and are generally OK under load. I'm not so sure about my hard drives - especially my M2 SSDs. They're generally idling in the high 40s, normal load in low 50s, and gaming at high 50s. I do have coolers added - one aluminium heat sink and one alu heat sink with a fan cooler. However one fairly significant problem I think is that one of the M2 slots us right underneath the GPU! So difficult to cool, and I'm not sure if the heat sink is making it worse or better. I've just put the SSD with the fan heat sink in that slot, and the temps gone up to 59c , so I'm suspecting there's just no space to ventilate. What are M2 SSDs supposed to run at, and what other low profile cooling options do I have?
Where do I plug the fans in?
The next obvious question is, where do I plug the fans / cooler into? To date, the Corsair H115i CPU water cooler has been plugged into the CPU Opt header, which the manual says is for a water cooler. The radiator fans were (and the new ones are again) plugged into the radiator fan extension from the CPU cooler, and the rear fan is plugged in to the Sys_Fan1/2/3_Pump header. The case comes with a PWM Fan Hub, but I've not used it. Should I??? Not even sure what benefit it provides?? Additionally, the new LL140 fans come with a fan hub / lighting node. My assumption was that this was more for the RGB lighting and that's where the RGB cables are plugged into. Should one of the CPU cooler cables go in here? Or is that what the USB cable from the CPU cooler is for?
How do you cool backplate mounted HDDs?
There's obviously no meaningful ventilation behind the backplate, where I've got my 2 x SSDs and 2 x HDDs mounted. With all the hidden cabling and controllers, there obviously isn't much space for air to circulate, so how are you supposed to cool this part of the case??
Graphics Card Mounting
The 3070Ti is mounted on the top PCIE 16 slot. It's a beefy card, and as I mentioned covers the lower M2 drive on the motherboard, so I suspect meaning it runs hotter than it should. There is an option to mount the graphics card vertically but I'm worried that it'll just push the graphics card up against the door and make ventilation even worse. Has anyone done this with one of the modern big cards??
Out of internal USB headers
Lastly, I'm using all of the internal USB headers with front panel USB 3, front panel USB 2, USB C, and the Corsair H115i CPU cooler. Therefore I don't have anywhere to plug the new fan controller into. Are the internal USB hubs worth the effort?? At the moment I've swapped in the new fan controller by removing the front panel USB2 plug, but I do use that a lot. Honestly expected front panel 4 port USB plus USB C to be provided by 1 plug, not 3!
Basically I think I should be able to make this more efficient than it is, and cooler than it is too, but not sure how.... Can you help??
Thanks!! 😀
Hot M2 drives?
Thanks!! 😀
