Corsair CPU Liquid Cooler Hydro H100i vs Corsair H80i vs H90
thugslife
205
Hi
I am willing to buy a closed loop water cooling kit looking forward to a Corsair One which is easily available in my country.
    Corsair CPU Liquid Cooler Hydro H100i Extreme Performance
    Corsair CPU Liquid Cooler Hydro H80i High Performance
    H90 140mm HIGH PERFORMANCE
I am confused that H100i is a 240mm and H80i is 120mm and H90 is 140mm
i want to know that which is better in performance creates less heat and less noisy............
there is no huge difference in price b/w 10$ or so
My System Specs
Intel Core i5 4670K-Asus Maximus VI hero Z87-Corsair Dominaor GT 8GB 2400mhz-Corsair GS 800-CM 690 III-WD Cavier Black-
currently using a Intel Stock Cooler
in this order #1 H100i the 240 will offer the best cooling how ever it might be to big to fit in your case. note there is also a newer version h110 same thing different pump. cools a little better too. about the same price..
as for the the other one i would look at the H90 as it would offer the best cooling for a case with a 140 mm fan which most cases do have unless you have a micro atx or smaller case..then it depends on the make. so will work others wont.
As mentioned i have a CM 690 III which supports only 240mm Radiator
Get the H100i. With the radiator's huge surface area - the cooling will be much more effective. It'll also maximize the space of your top 2x120mm mounting area. 😍
