hi thanks for answer, i from Indonesia and my budget is max $100No, they're slightly different in terms of internals.
The CX550 is a little better in terms of quality, with the 550M being semi-modular.
Of the two options, all else being equal, I'd opt for the CX550
That being said, if you're looking to purchase a PSU.... What hardware are you using? What kind of budget do you have? and where are you located? Corsair offerings have good worldwide availability, but there's frequently better units for similar money, or similar units for less money in a lot of areas.
Can still be ordered direct from Corsair, so doubtful it's discontinued at all.Corsair cx550 is discontinued? Almost all market place said that
Agreed with @King_V , a good 450W unit would be plenty. 550W wouldn't hurt.My spec pc:
I3 10100
Gigabyte b460m ds3h
Msi gtx 1650 super gaming x
Apacer 8x2 2666mhz
Fan 3rgb 2normal fan
Monitor samsung sr35
$100 USD is roughly 1.4m Rupiah?i from Indonesia and my budget is max $100
thanks, you suggest really useful for me... i will take 1 from your suggestionCan still be ordered direct from Corsair, so doubtful it's discontinued at all.
May simply be unavailable in some markets due to current conditions.
Looks like the CX550M is one of the cheaper options at <1.2m
https://www.rakitan.com/product-detail.html?kode=CSPSUATX0004X
There's a better quality LeadexIII, but looks like it's marginally over budget at 1.48m
https://www.rakitan.com/product-detail.html?kode=SFPSUATX012X
I'd be more inclined to opt for the SeaSonic COREGM500W for 1.15m:
https://www.enterkomputer.com/detail/162391/Seasonic-Core-Gold-GM-500-500W-Modular-80-Gold-Certified-7-Years-Warranty-Replacement
Or the FOCUS GM-650, still (marginally) under budget:
https://www.enterkomputer.com/detail/164457/Seasonic-Focus-Gold-GM-650-650W-Semi-Modular-80-Gold-Certified-7-Years-Warranty-Replacement
The FOCUS should allow for pretty much any upgrade you want to do & run fanless most (or all) of the time with the hardware you have.
Excuse me sir, now i found market place sell cx550($67,81) and cx550m($83,53), which one do you think I better take?Can still be ordered direct from Corsair, so doubtful it's discontinued at all.
Of the two, the CX550.Excuse me sir, now i found market place sell cx550($67,81) and cx550m($83,53), which one do you think I better take?
Thanks everyone, thank you for the response, i am very calm now because i know the best psu with my budgetOf the two, the CX550.
However, the FOCUS GM-650 is substantially better and within budget. I'd recommend that over anything else.
