[SOLVED] Corsair CX550M (gray label) vs FSP Hydro Fully Modular MX550
There aren't any reliable reviews of that unit, but the platform itself is "ok" and I doubt it's much, if any worse than the older CXm units. Probably better than the MWE v2. Should be fine for your system.
It's obviously not a top shelf or high end model, but it's not garbage either.
They are pretty comparable. I'd probably go with whichever one was the least expensive. Neither are particularly great, but they are probably plenty good for that configuration.
http://www.jonnyguru.com/forums/showthread.php?13603-FSP-MX550-review-itocp
I was going to get the CX550M Power Supply but it was not in stock, so I bought the Antec NeoECO Zen Gold 600W. Is it good enough? Is it as good as the CX550M? Should I replace it with the Cooler Master MWE White V2?
