Corsair CX550M help!
Course, if you look at the tier chart, it still lists it as a tier 4. If it were my hard earned money, I'd buy an EVGA or Seasonic from a higher tier.........
Never scrimp on the PSU, rule no. 1.
but i have read many reviews of this 2015 edition cxm series and they all say its good
Corsair CX (green label) are bad psu for anyone.
Corsair CX450M, CX550M e CX650M (grey label) changed manufacturing. They don' t have the problems of Corsair CX (green label).
Corsair CX750M (grey label) ed maybe Corsair CX850M (grey label) have changed only the label and they are bad as the Corsair CX (greeen label).
This is what I wanted to know, thanks. :)
so should i get a corsair cx450m or a cx550m?
Croatia, sweet:). Ok, on that website, the next psu down from the one you're looking(same page, same wattage) at is an FSP, that's a tier 1 it's about 15 dollars more(103 kunas more), using the websites numbers, and converting kunas to dollars. There's also 3 PSUs at the bottum of the page that are higher efficiency units that are top flights as well. That FSP is a gold rated efficiency model, if the budget matters, it's what I'd buy.
I know money doesn't grow on trees, buying a PSU is super important, it's why I'm stubborn about the issue, you don't want components starting on fire or frying cause of a bad PSU.
what about a seasonic g series 450w psu
ok thanks im gonna go with that seasonic psu beacuse I like really love seasonic's products and fsp i know they are good but I dont really like them
u just solved my problem thanks man!
Yes. CX450M, CX550M and CX650M are better than Evga 430, Evga 500. Evga 600 and Evga B (this Evga aren't bad psu).
If you have more budget you can buy on that site: Fractal Design Integrata M (is less efficient than Corsair CXM) < Corsair TXM < Corsair RMX (is top psu). Then i don't know what's your budger for psu.
Seasonic G is another top psu. It' s not particulary silent but if this isn't a problem for you, i recommend it.
