Corsair CX600M problem
ygp
20
Hi..
i have Corsair CX600M that I bought couple weeks ago. I'm not sure if this is a problem or its the way it supposed to be. Ok, since the first time I bought my pc, everytime I turn on my computer, the psu "died" twice before it finally turn on my pc.
here's the video : http://youtu.be/GKKpnMxhRbk
I'm not sure if you need my full spec but here it is :
mobo : ASUS MAximus VII Ranger
gpu : MSI Geforce GTX 970
memory : 16 GB corsair
psu : corsair CXM 600
processor : i7-4790k
watercooling : Corsair H100i
is it normal ??
please let me know if you need more information.
Regards,
It´s a feature, not a bug. With newer BIOS, it should be gone:
http://rog.asus.com/forum/showthread.php?49641-Maximus-VII-Ranger-Cold-boot-issue-Turns-on-then-off-then-boots/page2
BIOS up to date? Just flash in BIOS/UEFI itself, never in Windows!!
http://www.asus.com/support/Download/1/45/6/15/n1YzcJITwZrK4LaT/30/
The board will do that, if changes in BIOS happened or when it´s disconnected from Power.
Is the ATX12V 8Pin plug plugged into the Mainboard and not just one 4Pin plug?
Did you test your rig?
memtest86+ ,
cpu with prime95 + coretemp, furmark for graphics card, Temperatures after 10min
3dmark 2013 benchmark, please post the result link after the test
the video link is privet we cant see it. if the system when you turn it on powers up then down then up a few times then boots. what going on is the motherboard cant set the ram and cpu speed right and it overclock failing. on older mb that did not have this feature people used to have to clear the cmos and then restart there settings. on your mb make sure the mb has the newest bios file. under ai tab turn on under dram speed. xmp profile turn it on use profile one. see if the error stops.
i have no idea where I should look..sorry im newbie..but yes all the connectors are tight
that is exactly what happened. sorry its public now you can see it. https://www.youtube.com/watch?v=GKKpnMxhRbk
is this what you mean? http://puu.sh/cOWiW/f485c02fea.jpg
i can't find xmp profile..sorry im newbie...
enabled xtreme tweaking that under DRAM frequency and enabled xmp profile 1..the problem still occur. T__T
i did enable XMP. it didn't fix the problem tho. my friend said its completely fine, but i don't know..it wasn't supposed to be like that, was it?
memtest86+ ,
