Corsair CX600m PSU fan replacement
kyle bevington
29
So i am building a gaming rig and my theme colour is blue and i am wanting to replace my Corsair CM600M PSU stock fan for a blue one but i do not know what connection they use so don't know what fan to buy
Please leave advice and answers bellow
Thanks in advance
Not to mention you would be running the rish of electricution if your hand slips. PSU modding inside it's case is very dangerous. You CAN DIE from this. Just get some LED strips.
Remember that A) you'll void your warranty and B) if it's in a conventional position (ie pointing down) then LEDs won't make much difference.
Some PSU fans are hard wired, but it looks like the CX600M (assuming that's what you have, there is no CM600M) has a 2 pin header which can be directly unplugged.
For more images see here, here and here.
Most fans are 3pin or 4pin (PWM) so they won't plug directly in. You can likely rewire the connectors if you are so inclined, otherwise a 3pin to 2pin adaptor should work.
Yes sorry it is not a cm600m it is a cx600m, so do you recon a after market 2 pin fan will then
