Corsair Cx750 questions regarding build
if u are going to oc the processor and the card dont get the cx series its not meant for gaming pc its an entry level psu series with low end capacitors and can throttle at loads and definitely not for a SLI system get seasonic 80+ gold 750 - 850 watt psu if u are planning on sli in future more efficiency more better in SLI system...
I just bought a laptop recently so am low on funds, I want a PSU, will definitely buy one soon but is it necessary at the moment? I changed the build a little bit.
My question to you my good man is will the Cx750 be ok running all of this or will it get damaged etc?
http://gyazo.com/d42025734033f654855ca83a74c80db3
I won't be running SLI just yet, until I get the new PSU
Ahhh ok, I think I understand now 😛
Thanks for the replies guys/gals really appreciate it!
Will keep the Cx750 until I SLI and OC
