[SOLVED] Corsair fan decisions help
Dec 31, 2018
21
For the front, I will be using push/pull with h150i. I will leave out the stock ll120 fans if there's a better option. so now, 3x120 front intake, 2x140 top exhaust, 1x120 rear exhaust. Which fans are the best for my case? would using all ll series be fine? or the front push fans must be ml for better airflow?
The LL fans will do the job for most systems. They won't be quite as good or efficient as the MLs but the difference is usually marginal. That's especially true with push/pull.
