Question Corsair fans not showing up in ICUE
Aug 14, 2019
Hi
I currently have 6 of the same Corsair LL120 fans installed in my computer, 3 on an H150 pro that are powered through the H150 and 3 as case fans that are powered through the motherboard. I have them all plugged into the same fan hub which is plugged into the lighting node pro. Right now when I open up Corsairs program ICue I can only change the speed on the 3 fans plugged in through the H150 but can change color and monitor the speeds of all 6 fans. Would I need to buy a Corsair Commander Pro to be able to change fan speeds for the other 3 fans? If not are there any other ways to change fan speeds without going through the BIOS?
Thank you
