Corsair h100i cpu cooler
What do you mean, exactly? The H100i is an AIO (All In One) liquid/water cooler. The pump/heatsink combo connects to a radiator which is cooled by fans. That is the only way to use it. It does not offer an "air cooler mode" if that's what you're asking.
Do you guys now a alternative that has rgb lightning and maybe is from corsair?
Without AIO?
And how do you setup AIO with a corsair cooler like H100i?
There are two basic styles of CPU coolers. Air coolers that come in the form of a tower or horizontal cooler such as this
https://www.newegg.com/Product/Product.aspx?Item=9SIA85V66M4911&Description=Cryorig%20h7&cm_re=Cryorig_h7-_-9SIA85V66M4911-_-Product
And all in one liquid coolers (AIO). AIO’s consist of a pump that mounts directly to your cpu. Two hoses will connect this pump to a radiator you mount to your case wherever you have fan mounting points. These are closed systems that contain water. You do not add or remove any water. They come filled and are ready to use out of the box.
https://www.newegg.com/Product/Product.aspx?Item=N82E16835146059
