So close to a year ago I purchased the Corsair H100i CPU Liquid Cooler from Newegg. Ever since I purchased it, I have had issues with it. Every 2-4 weeks, the cooler will flash from red to blue and the pump will be at 0rpms. The only way I have found to fix the issue was to reapply thermal paste to the CPU and remount the cooler. So last month, I decided I should send it in for a repair/replacement because I am just fed up with spending the money on thermal paste and time to fix it. I just want it to work. I got it back, and it seems like a whole new device. It was all packaged like it was new and even had the cables organized and connected together. So after I saw how it was packaged, I totally thought it was brand new. Now over the past month and a half, the device pump had failed twice, and the led is flashing colors again(I guess it does that when the pump stops working). I recorded a video for you all to see exactly what it does, and the cpu temperature to show you that the pump DID fail once again.
Youtube Video of this Issue - https://www.youtube.com/watch?v=ryXLi6UiVPk&feature=youtu.be
If anyone has a fix for this issue, it would help me out greatly. I have tried many things to try to fix it but here are some of the common steps I see on these forums that I have already tried multiple times.
- Uninstall/Upgrade/Downgrade Corsair Link Software
- Check bios for the CPU fan speed rpm
- Change pump connector to new fan connector
Here are my system specs as well
- i5-3570K (I've tried the stock clock as well as overclocking, but have noticed that overclocking makes the cooler fail quicker.)
- 4GBx2 Corsair Vengeance 1866 DDR3
- MSI Nvidia GTX 970
- Asrock Extreme4 Z77 Motherboard
- Hyperx 3K SSD
- 1.5TB HDD
- 750W Seagate PSU
- NZXT H440 Case
- Windows 8.1 64bit (Recently reinstalled windows because I like my computer to be clean)
I am open to trying pretty much anything. Just really want this problem to disappear!
TLDR - Corsair H100i pump fails after a few weeks. Flashes red and blue at 0rpms randomly. Have tried many things to fix, even sending to Corsair, but have not found the solution. Temp fix is to reapply thermal compound.
- Hyperx 3K SSD
- 1.5TB HDD
- 750W Seagate PSU
- NZXT H440 Case
