Hi guys as the title says I've got a corsair h100i and the temps seems abit high considering its a watercooler. At idle the water temp is 31c and the CPU temps is bouncing between 41c and 45c but its very erratic hitting 51c now n then i'm also using thermal grizzly conductonaut so i was expecting much cooler temps at idle i also have the pump and fans set to moderate and the CPU undervolted to 1.18125. I've reapplied the waterblock a few times and checked to see if i applied to much paste to the CPU but all is good. I know those temps are ok but not when you've payed over £100 for a cooler that supposed to be superior to the factory cooler.
