corsair h100igtx pump noise
Bill Hilly579
227
I'm having an issue with my h100igtx.it seems to make a rattling noise on quiet mode which I can confirm is coming from the pump.i disabled my hdd gpu and case fans to be sure.is this something normal with this cooler or should I be worried?by the way I have recorded a vid that I will probably upload tomorrow if nessesery.advice would be apreciated
hi and thanks for your reply.with the cooler its just loud enough for me hear it out of my case is that also normal?
I can't answer to this... better upload your vid to avaliate your noise and put it in the corsiar forum...
