Corsair h110 and Noctua NF-A14 PWM
Mehoe
Do you think mounting 4 Noctua nf-a14's in a push/pull setup on a Corsair Hydro Series H110 is a good idea? I've seen all the reviews saying that the included fans that come with the H110 are Crap so should I put custom Noctua fans on it or should I just get a Noctua air cooler?
Thanks.
if you cant bear the noise from h110's fans then replace it with noctua fans are best way but noctua fans tend to be more expensive so reconsider for other brand fans
