Do you builders use the thermal compound that is already on the header? I wonder what type of compound Corsair used?
I think it will be okay to use. Why would Corsair use a compound that would cause damage or problems? They would`nt be able to keep the product on the market if the stuff did`nt work.
Do you guys use the stock thermal compound that is already applied? How did it perform?
