Corsair h110i GT possible pump failure
CGurrell
1,098
Hi guys,
Had a corsair H110i GT for around a year now, turned on my PC today after around 2 weeks of not using it, and got a CPU Fan Error on boot. Got into windows and started up Link 4, Link is showing the Pump running at 0 RPM and CPU Temps of 80-90C. Once I saw the Temps I turned it off and it hasn't been on other than for BIOS troubleshooting.
Basically I've tried a different SATA harness to the one that was i originally using to power the pump, but no changes in behaviour. I think I have a bad pump, but this is my first AIO so I'm not sure if I've missed something simple
Any help is greatly appreciated
Thanks
1| The temps being at 80-90 Deg C is an indication of the fan not working or that the pump inside the housing has failed. It's a good idea to contact your seller and Corsair to initiate an RMA.
2| Can you please pass on your full system's specs inclusive of your OS? If it's that which si stated in your sig space, please make an effort to post it in your thread's body since this thread and it's solution will become irrelevant to a user with the same issue further down the road after your sig space specs change.
3| Just to be on the safe side, are you sure your motherboard BIOS is up to date while maintaining that the connections to your cooler are as stated in the manual?
