So everything was running fine, no issue, took things apart to add some fans, put ml140pro fans on outside in push then ml140pro blue leds on the inside as pull, all the sudden the second side of the splitter doesn't want to work, question I have is it safe to run a bunch of splitters on one side of the mail port, or is it ok the bypass the pumps fan header and plug Y spitter into each CPU header, top two to cpu_1 bottom two to cpu_2?
