Question Corsair H115i and lightning Node USB headers
chancemitchell
92
9
4,645
Motherboard: X570 AORUS WIFI ELITE
AiO: Corsair H115i RGB Platinum
Corsair LL120 3-pack with lightning node.
I have a H115i RGB Platinum. The USB cable from the CPU cooler to the motherboard consumes two USB headers on my motherboard. My motherboard only has two USB headers. To use the lightning node I need another USB spot. Is my motherboard not compatible to run these components. Or is there a way to wire all of these components to work. My case currently has a PWM controller and a RGB node. The Corsair came with a controller and RGB hub. My fans are on but the RGB doeesn't work. Is this because I don't have the lightning Node hooked to the MOBO?
