Corsair H115i Fan Replacement
Necdet
hey there,
So i just got Corsair h115i for my CPU. And the stock fans on radiator are too loud so i decided to change them. I heard a lot of people using Cougar fans. Is Cougar Turbine 140mm will work with it? Will i be able to control the fan speeds on Corsair Link?
If you're looking to still maintain fan speed control using Corsair Link, you will need PWM fans and they have to be connected to the Y-cable coming off the pump that the stock fans plug into. The ML series fans we offer will work great when installed to the H115i and provide low noise levels like you are asking for. They can also be used for case fans too if you want to upgrade the whole case.
I know. I can control control them in bios or softwares. Its called Corsair Link and it allows you to control fan speeds. I tried every speed and profiles. On quiet profile its nearly same as max speed. Its the fans they are like jet motors 😀
