[SOLVED] Corsair H150i Pro Front Mounted in a Define R6
kepmip86
Hello everyone how are you?
Been a Noctua fan boy for some time and wanted to make a switch with my next gamer build by going the water route in a Define R6.
I wanted to go with the 360mm H150i pro AIO and wanted to have it front mounted with either push fan or push/pull configuration.
I know a top mount is possible but heard some people get into issues with clearances. Plus wanted to have a cooler cpu. Unless someone can convince me it wont matter to much :)
I know the H150i pro would fit comfortably in the front from the supplied specs but i can't find any information on tubing lengths and their compatibility as it seems the front of the case is a long way from where the cpu is.
So i am wondering if anyone happens to know if the H150i will have tubing length issues reaching the cpu when front mounted?
Thank you very much in advance.
Kind regards
Kepmip
