https://vocaroo.com/173yuHGCOY6t here is the audio recording. You can hear it, kind of sounds like a dial tone... When the fans are not spinning this noise stops as well. It drives me nuts and I don't know what's causing it.
Well if I manually set it to 0 rpm it stops completely, if any increase in speed just makes it more audible.Does the sound change if you manually set the fan speed?
Where is the radiator installed in the case?Well if I manually set it to 0 rpm it stops completely, if any increase in speed just makes it more audible.
At the top of the caseWhere is the radiator installed in the case?
Are the fans blowing air out on the radiator or blowing air into the case?At the top of the case
