Thank you for your reply! Will it keep the full stress temperature average of 70-80 degrees Celsius?CORSAIR H55 RGB 120MM LIQUID CPU COOLER will have no trouble cooling the 5700G. The stock cooler is not that great.
yes it should if it's installed correctly.Thank you for your reply! Will it keep the full stress temperature average of 70-80 degrees Celsius?
Okay, thank you so much!yes it should if it's installed correctly.
You will find that the radiator size of a 120mm aio will limit the cooling capability of the cooler to the equivalent of a 120mm tower type air cooler that costs 1/3 as much.
Noctua maintains a table of suitable coolers, here is the list for the 5700G:
It looks to me like you need more than the H55.AMD Ryzen 7 5700G | CPU Compatibility | Noctua Compatibility Centre
Series: Cezanne, Socket: AM4ncc.noctua.at
Noctua is premium quality.
There are some lesser twin tower air coolers that still do a very good job.
Thermalright peerless assassin for example:
Thermalright Peerless Assassin 120 SE Review: Incredible, Affordable Air Cooling Performance
Shockingly cool and quiet, less than $40!www.tomshardware.com
What is the make/model of your case?
It should be fine for a 5700G but not more than that. If it's the Wraith Stealth you have then yes it would be an improvement over that.Hi, I built a pc a few days ago with Ryzen 7 5700g. Is it enough to cool it using CORSAIR H55 RGB 120MM LIQUID CPU Cooler to keep the full stress temperature average 70-80 degrees Celsius? I'm using the stock cooler for now because of the budget.
