Corsair H60 buzzing noise
Anthonyk96
33
I recently bought a corsair H60 to replace the stock fan on my FX 8350 and I thought it was meant to be silent, which is the reason I got it. Whilst playing the battlefield hardline beta I noticed a pretty loud buzzing noise coming from the pump, I don't know whether I have a faulty pump or the radiator is overheating causing the pump to buzz. Also the case I am using is the NZXT H440 if that makes a difference.
Any help would be appreciated thanks.
The temps seem fine - if you heard the noise, I'd suggest that it is a pump issue. That or you have extremely sensitive ears. :) Even my dog's aren't bothered by the pumps on any of my liquid-cooling installs. :)
The Installation went fine I left the pre applied thermal compound on and installed it without any problems.
I just downloaded and speccy and checked my CPU temps at idle my CPU temp is between 25 and 30 degrees and while playing battlefield it hit a max of 52 dgrees using open hardware monitor.
Okay thanks 😀, I'll see if I can get a replacement from corsair.
