M MAEryzen Prominent May 13, 2017 2 0 510 May 13, 2017 #1 I have a Ryzen 7 1700. I am cooling it with corsair h60 and temps have been at 38 / 40 degrees at idle and on load at 50 degrees celcius. Are those good? Should I change to H110i or a NZXT
elbert Champion Jan 11, 2005 9,704 6 51,165 May 13, 2017 #2 Those are great and the Ryzen can hit near its max safe OC with mid range coolers. The H60 is all you need. Under 71c and 1.35v is good. Upvote 1 Downvote
atljsf Honorable BANNED Jun 17, 2015 4,910 46 12,990 May 13, 2017 #3 those values are perfect, the h60 is doing a great job there is working with 1 or 2 fans, in push pull? Upvote 0 Downvote
M MAEryzen Prominent May 13, 2017 2 0 510 May 13, 2017 #4 I added a second fan push and pull. Thanks guys Upvote 0 Downvote
atljsf Honorable BANNED Jun 17, 2015 4,910 46 12,990 May 13, 2017 #5 thats why it works so well Upvote 0 Downvote
elbert Champion Jan 11, 2005 9,704 6 51,165 May 13, 2017 #6 You are most welcome and please return to tomshardware with any questions. Upvote 0 Downvote
