I've just bought a Node 304 case and thought I would buy a H60 for more a sufficient and quieter cooling solution.
The H60 sounds like a jet engine starting up when I play a game or do anything intensive. It fluctuates when idle but I've checked the temperature of the CPU (i7 4770k @ stock speed now) and it seems to be around 37-42 degrees. It goes up to around 55-60 degrees when playing a game such as Counter Strike. I used Arctic Cooling MX4 thermal paste for the CPU when installing the H60.
This is the same layout I used for mine.
http://www.overclockers.com/forums/attachment.php?attachmentid=151666
I mounted the radiator and fan to the top of the case rather than on the back side by the I/O.
This is the first timed I've used watercooling in a build; currently the stock heatsink is quieter than this H60. Anybody know how to fix?
