corsair h70 liquid cooler
Jyoti Sahoo
18
i have a stock cooler for my cpu amd fx6300 and it is crap. i want to switch to a new one.
the problem is will it worth to buy a $100 liquid cooling system corsair h70 or a normal heat sink will suffice?
actually just did some goggling h70 should be fine for you even if you are planning on an over clock. but the H80 is the best single fan rand on the market.
yea amd stock cooler are pretty horrid. im prety sure the h80 would be a better buy tho.
price difference is much ..will there be comparable performance difference. how about the h50?
will install in right away.
you already have one 😛 well good luck
i might not OC ..not covered in warrany.
it sure looks promising. its a cheaper too...
i just saw this
http://www.maximumpc.com/corsair_hydro_h70_liquid-cooling_system_review
the corsair better at loads.
i will go with liquid cooler.it sound cool too :) thanks
btw my rig is open i want to enclose it inside a glass and set it on the table..the liquid cooler will look good in it 😉
no worries :)
