Corsair H75 makes single click sound when booting,shutting down or restart?
ZeRo_DiNero7
64
Hi guys this is my 1st water cooling and i got an corsair h75. Everytime i restart or shutdown or booting up the pump makes a single click sound. Other then that its really quiet. I installed the 2 fans of the cooler on the cpu fan header with the imcluded Y cable and the water pump in the w_pump header ony asus ranger. Is this normal?
Also sometimes i hear the liquid inside the cooler like a squirting sound and then i dissapears?
Any help would be appreciated
The tick sound could be due to a component in the cooler turning on and off, not un-usual since one of my h60's does it as well.
As with the squirting sound, usually it's just the liquid going around the loop and some air bubbles move in such a way that it creates the noise. Then disappears after the airbubbles move to the top of the cooler. Usually once these air gaps settle in one position (since you arent changing the orientation of your PC all the time) the sound goes away.
None of this is bad though, as long as there's no leaks and performance is good, then it's all good 😉
-good luck
-good luck
