Question Corsair H75 problem
innis2
8
after clean some dust and change back fan intake to exhaust (i put the radiator as top exhaust),when tried the pc back on, fan goes full speed and temp got to 90~100 degree
when i clean, i didnt touch the cooler/pump at all ...then trying to give more press with hand while pc on , but didnt change anything
when i saw hwmonitor, the pump still show the rpm number, then i tried to change pump plug to other socket and molex socket extension from psu, but still same result
and its been 5 years since i use this cooler though ...
so any other thing i should try?
and if i need to change the cooler, i saw cryorig h7 is decent and silent but maybe any other good recommendation silent hsf for i7 7700?
i dont need rgb, and maybe for budget not higher than cryorig h7 ... still have other needs to do
thx b4, and sry for bad english
