I have the Corsair H80 Hydro Series cooling my CPU.
Check list of what I have tried.
Reseating the mount.
Cleaning and reapplying new Thermal Compound
Checking Voltages
Cleaning the fans/grill
Hardware:
2600k
H80
I am completely confused as to why it is overheating with 0% load...Yesterday I was running multiple programs and it was at 60C then turned it off later that day and it was overheating again... Today I am getting nothing but 85-96C which is terrible for a CPU to be running at. The fans are running fine. The little white guy on the controller for the H80 is blinking I can only assume its because of the temperature of the CPU. My only guess after all this trouble shooting would be the pump is faulty. Though touching one of the tubes it feels hot and the other cool which is how it should be. Input and output... This problem is extremely frustrating as I can't do much of anything with my beastly computer without the chance of frying my CPU. And help or suggestions, even the dumb ones are welcome. I am at a loss.
Checking Voltages
Hardware:
2600k
H80
