Corsair H80i. CPU fan error with Red Light on pump. help me please.
praveen1996
67
When i turn on my pc it boots into bios and shows cpu fan error. The pump is glowing red(not blinking).when i enter the bios by pressing f1. The rpm of cpu fan is N/A. The cpu temp rises and automatically shuts down.. I have looked the connections of h80i. All connections are good. Please help me to solve this one
1) The fan error would exist likely if using the Corsair setup and NOT connecting to the motherboard. In the BIOS the motherboard sees no CPU fan. So NOT an issue.
2) PUMP color can be changed I believe so not necessarily a problem.
3) SHUTDOWN and Overheating is obviously a problem so it sounds like a defective pump.
4) So, contact Corsair to RMA.
5) Another option is to RMA it, buy an AIR COOLER instead, then sell the returned cooler.
*The Noctua NH-U12S is a really great cooler. With a good air cooler you can also run the computer even if the fan fails depending on the software running.
I cutted the three pin molex cpu fan connector and replaced it with other three molex pin (it was loose.. shaking it made the pc to boot. So i thought it was the problem). Will they RMA the piece.. Im in india (rma is available here or not) .. Im in a pathetic situation please help me!!!
Anyone.. Reply please..
Not likely now that you did that.
I also have the same problem, when I install my h80i not pass bios logo and Corsair flashes red, my motherboard is an Asus Rampage IV Gene, I could never fix and I had to buy another cooler.
